Does any one know where the fan switch is on the avu engine. There seems to a sensor on the bottom of the radiator but it only has two prongs coming out of it, shouldn't the switch have 4?
Fan switch on a avu engine?
Everything you need to know here http://pics.tdiclub.com/data/516/A4_...ting_Rev_7.pdfMK4 GTI - Sold
MK5 Jetta Turbo - Sold
Ok I have Actually run power from the battery to the fans and they both powered up, and when I turn on the a/c the fans start spinning. I thought the switch might of been in a different place maybe they only have one speed on the avu engine judging by only two pins. Maybe the module is playing up. Because as I have found from other vehicles if you bridge the plug the fans usually come on, but not in this case.
The radiator thermo switch is quite large and is triangular at bottom of radiator, 3 large pins. The 1st pic, yellow, looks like a temp sensor small current device not for switching large loads like a fan.
Last pic looks like the coolant junction at the side of the engine it has a coolant temp sensor also.MK4 GTI - Sold
