Hi, and thanks for reading. Long story follows. I own a 2003 2.0L Mk4 with low kms (<90000). For any other readers in future with similar problems, I promise to post a final outcome no matter what.
A few weeks ago, it had trouble starting, particularly after the engine had been running. This problem got worse over time, and within a week, it would hardly start at all. The car would turn over fine but won't catch. New battery, so it wasn't the battery.
I managed to get it to my mechanic who couldn't diagnose because he said he couldn't get a reading from the computer. Recommended it go to a specialist auto electrician.
Auto electrician said the same thing. After inspecting the ECU, they noticed some corrosion on the harness and cleaned this up as best they could and returned the car to me. It started well enough for a week but the same problem came up the next week - we drove back from Wollongong to Canberra and the car wouldn't start after we got back home.
Took it back to the auto electrician who returned it to me without much more to say. They said they could replace the harness ($1300 each side, plus labour at $130 an hour) or the ECU ($2500, plus labour) but unlikely to be worth it for a car of this age. More realistically, they offered to replace the starter motor for $550 which sounds like its straining. I should note that the starter motor is working.
Car finally died on the weekend. Cut out and stalled on a major road and wouldn't re-start. Had to get it towed home.
After some research, I ordered a new cam shaft sensor from bosch and manage to fit it. The problem persists, but it's possible in replacing the sensor, it's possible I nicked the black wire leading to the harness. I could splice it but I'm not sure this is the main problem.
I only need the car for a few more months, so I'm reluctant to plough a heap more cash into it. Equally, I'd rather not write it off if there is a reasonable fix for it.
Grateful any ideas you might have. I'd rather have a car in summer to drive the missus and little one around in - she's only two and can't walk very fast.
