"Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)
  • "Wolfie" Golf Mk4 1,6L AKL 5sp manual DUU - Build :)
    Hello mk4 land! I recently acquired a 2001 Golf Mk4 in Reflex Silver. It's the POVSPEC 1,6L petrol, engine code AKL, with everyone's favourite 5sp manual gearbox code DUU. For your interest here are some of the mainly aesthetic & comfort mods I will be undertaking:
    01 Pioneer AVIC F-960DAB Digital Radio Navigation
Name:	01 avic f960.JPG
    02 Polaris Heads-Up Display
Name:	02 polaris hud.JPG
    03 Illuminated italian leather shifter boot, made in Germany
Name:	03 shift boot.JPG
    04 ESUSE custom DRL for mk4, made in Taiwan
Name:	04 esure drl.JPG
    05 R-dash number plate lights (from Polo 6R)
Name:	05 Numberplate LED.JPG
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
    06 Hella 'Magic Color' Smoked black taillight clusters
Name:	06a Hella Magic.JPG
ID:	1812955 . Click image for larger version
Name:	06b Hella Magic.JPG
    07 W8 dome light with illuminated switches and ambient LED light
    Needs a wire taken up the A-pillar carrying "Klemme 58d" dimmed illumination power
Name:	07 W8 dome light.JPG
    08 Rear View Camera installed above numberplate
    I could install this easily without removing the bumper. Just take out the plate bulbs and manoeuvre the wiring with fingers/tools/cable snake.
Name:	08 RVC above numberplate.JPG
    09 OEM short FM antenna from Polo 6R
Name:	09 OEM short antenna from Polo.JPG
      10 Remote central locking kit installed under dash, wired into driver door.
      Got the unit for less than twenty bucks on eBay. The local locksmith cut the blades $40 each, and then had to get ID48 transponders from KeyMam for about $10, plus the old VagTacho off eBay, as described in the great sticky on this forum.
Name:	10 Remote central locking kit.JPG
      11 LED footwell lights
      They are wired up to the dome light: they turn on when you unlock the car, open the doors, or use the dome switch. Very 'stock' like
Name:	11 Footwell lights.JPG
      12 Sony wired remote control RM-X4S.
      An alternative idea is to fit a Mk6 GTI wheel with the DSG paddles, and develop an Arduino board to interface between the MFSW LIN bus and the Pioneer. The Arduino would take over the horn wires in the slip-ring on the wheel side, and then provide a horn output on the car side (in Mk5/6 the horn runs over LIN bus). Also the arduino would have to convert the 58d dimmed lighting input signal to a LIN bus command to turn on the MFSW illuminated buttons
Name:	12 Sony remote.JPG
      13 New OEM boot struts so the hatch doesn't hit my head
      Cost less than forty dollars posted from overseas. No idea if a 'regas' would have been cheaper - but definitely more effort I presume.
Name:	13 OEM boot struts.JPG
      14 New fuel filler cap solenoid
      The old one died on the "door always open" position. I look forward to pulling all of the boot trim apart to accessing the damn thing.
Name:	14 fuel filler solenoid.JPG
        Oh, and lucky last for now:
        15 FIAMM® Freeway Blaster Horn
        The stock horn's meek 'meep meep' sounds like the road runner, or maybe a scooter. And this is Melbourne after all, so we need a good horn.
Name:	15 Fiamm Freeway Blaster.JPG
        Other stuff:
        Soft touch plastic
        - I gutted the interior off all the plastics which were plagued by the dreaded "soft touch" deterioration, it was all sticky-icky and peeling with hairs stuck to it etc. etc. The trick to fix it was using 100% isopropanol (or 100% ethanol works great too, if you can come by it ) to actually dissolve the soft touch stuff, to reveal nice black plastic underneath. No need for scourers or anything, just a whole lot of cotton cloths. The black gum will actually end up on the rags, I used about 10 rags to get rid off it all, took about 3 hours.
        Gear lever became 'sticky' when car warm, and won't return to neutral position
        - When the car was warm, the side-to-side movement of the gear lever would become difficult to move, and the lever wouldn't return to the neutral position. This made it hard to tell which gear I was shifting into. The car had just had the transmission shift linkages completely renewed. The problem was solved by spraying silicone lubricant and white lithium grease onto the shift linkage pivot points (under the hood near the transmission) and now it shifts super smoothly. Interestingly most of the info I found online (US based) related to a dual cable-based manual shifter, however the 1,6L manual has an old single rod-style system similar to Mk3 and Mk2 (I believe), this is what it looks like all greased up:
Name:	Gears greased with lithium.JPG
        DUU transmission
        The car needs a new clutch soon. Would it make sense to install the stainless steel bolt kit into the transmission at the same time?? Or just wait until it fails & cracks and fix it then.... It's been fine now for 170'000km, so maybe it's not affected by the shearing rivets on the final drive gear? Any advice appreciated
        Thanks for reading.
          The Polaris HUD seems really cool! nice to see another person modding a non gti mk4
          01 MKIV GTI ME7 converted hybrid k04
          08 MKV GTI Daily driver duties
          I have serious VAG issues.
            Wow nice shopping list.
            Can you give some detail about those gas struts for the hatch ? I got decked last week, knocked me to the ground, had a headache all day.
            If your horn sounds like road runner, then the bass horn is probably gone, there are two
            MK4 GTI - Sold
            MK5 Jetta Turbo - Sold
              Hi JC the hatch struts part number is 1J6827550C (for both sides, and also the same for the single one that holds the bonnet up) I ordered a pair from this link:
              VW Passat B5 5 Wagon Bora Golf MK4 Tailgate Damper Shock Strut Prop X2 Pair | eBay
              Another seller had them in stock locally in Melbourne but at twice the price.
              Do you know where the second (low) horn is? Mine has a single horn just behind the front foglight vent on the L side of the car.
                Can you put the w8 in a non sunroof car?
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                  Hi Dylan there seems to be a sunroof and non-sunroof version of the so-called W8 dome light: The non-sunroof version is the same size as the standard mk4 dome light. In some cases, some foam in under the roof liner needs to be pushed aside or cut away, because the W8 light plug comes out at 90' degrees to the side, whereas my stock one the plug comes out straight 'up'.
                  The light I got included the adapter for stock <-> W8 connectors (ebay germany I think it was) - so no soldering required. But to run the illuminated buttons and ambient LED, it needs to be wired down to the dash.
                    Daytime driving lights installed:
                    They are plenty bright
                      Pioneer AVIC double DIN unit installed:
                      Needed lots of wiring (reverse, speed sense, separate DAB antenna stuck to the window...)
                      Dynamat on the outside door skins:
                      I was too lazy to do it properly on the inside of the doors. Taking the skins off allegedly requires removing or taping the windows glass, etc etc. I'll do it when the window clips break and I have to replace them
Name:	02 dynamat door.JPG
                      Picture of the center console removed to help clean the soft-touch stuff off, and to run wiring for the illuminated gear knob still to come:
Name:	07 console removed.jpg
                      I also cleaned out the insides of the instrument cluster. Turns out it's a crappy Bosch "MotoMeter" RB8 unit, not made by VDO, so that's gonna be fun trying to get the PIN/SKC code from using VAGTacho... NOT!
Name:	06 instr clust.JPG
                        Ahhh didn't know there was a non sunroof one, cool
                        Bora gone
                        Vento VR6
                        MKIV GSW TDI
                        7P Touareg TDI
                          You can still get the SKC , but you will need the car hooked up to a decent charger as it can take at least an hr to seed the key. They can be a pain but still doable. Oh and yes the clutch is 80-90% worn, your not wrong there
                          Jmac
                          Alba European
                            Good to see another 1.6 getting done up
                              Photoshoot
                              Photoshoot after 'paint correction' using an orbital polisher and Scholl S3 & S17:
