I noticed on my VCDS scanner the other day that the ECU coolant temp value in block 003 was only getting up to around ~65° max, but the Cluster coolant temp is showing 90°+ at the same time....?
Are they separate coolant sensors or does the cluster/ecu share the same sensor?
Any other reason they would not be reading the same temp?
