Cost for new clutch, brake fluid & Coolant change
  • Cost for new clutch, brake fluid & Coolant change
    Hi All, Seeking information on what is a reasonable cost to change clutch, renew brake fluid and coolant. My mate with Mk 4 GTI has been quoted between $1500 and $2500 for the above work, is this reasonable or over the top?
    Regards
    Jon
    You could be charged an easy $1500 for a clutch change. Really depends on the clutch the mechanic uses, and the labour charges for the change.
    Typically, most mechanics charge around $100/hour and the typical clutch change is usually around 6-8 hours. Being a fwd makes it a little easier than an awd but it's more difficult than a rwd car so you pay a bit more labour.
    My car was fitted with a Bora V5 clutch and it cost the previous owner about $500 to buy.
    As for the brake fluid and coolant change. That's easy DIY. Save some cashola. However I'd expect 1-2hrs labour for s coolant change and brake fluid flush a piece.
    Originally posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
      Agreed. The biggest expense is the clutch. The labour in that isn't so bad. Most workshops could do that part of it in half a day. They're pretty easy to do.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        What clucth ? Dual mass flywheel and clucth kit is the OEM spec way to do things.
        When I had mine done the flywheel and clutch was about $2K plus labour.
        Change to single mass is a lot cheaper. $900 + labour
        Fluid change is going to be nothing compared to the clutch work. 1 litre brake fluid 5 litres coolant and 1 hour labour under $200 I'd say.
        MK4 GTI - Sold
        MK5 Jetta Turbo - Sold
          I just got my clutch and flywheel done. Put in a single mass flywheel which I bought from ecs. Got the dealers to put it in. All up cost $1200ish.
            Thanks for your help
            Regards
            Jon
