Help required How to remove radio in Mk 4 Gti
  • Help required How to remove radio in Mk 4 Gti
    Hi Can someone provide details on how to remove the radio from Mk4 GTI as I need the serial number to find out security code.
    Thanks
    Jon
    get a wire coat hanger and bend so it goes into both holes on both side and pull!
    MY MK4 BUILD
      Thanks
      Jon
      Just call VW and quote your VIN number, on both your rego sticker and on top of the fire wall and they will quote you the pass code. much easier than pulling it out
      CURRENT: DBP Mk4 Golf .:R34 no. 187 (WOOKY)
      Mods: C2 Motorsport Custom Tune | 268/264 schrick cams | Eurospecsport forged rods | JE forged pistons | Miltec Headers back | Higher compression | Engine fully ported | polished balanced crank | Sach Motorsport clutch | Single mass flywheel | Wavetrack LSD | Shortened 4th/5th/6th | etc etc |
        Thanks very much, I will ring Monday. And thanks for telling me how to remove. I guess you mean the little holes (2 of) on both sides on the front panel?
        Thanks
        Jon
          I assume you have checked for the radio code printed on a card with the service manual in the glove box.
          MK4 GTI - Sold
          MK5 Jetta Turbo - Sold
            Yep, nothing there, checked everywhere, even spoke to previous owner.
              Hi mate, I tried what you said but I didn't have any luck. I inserted 4 pieces of coat hanger wire into the 4 holes about 150mm long, I could feel it going past what I imagine to be the locking pieces and then hocked another piece into the cd opening and pulled but the radio wouldn't budge. Is there anything else I need to do at the same time?
              I went to the dealers (Cricks in Maroochydore) but they said it was too old to be on the system.
                Try another stealer, that's bull ****, I asked about 18 months ago no worries, if they had it then, they'd probably have it now.
                With the wire, if you go too far in you can foook the clips, which is exactly what I did when I was putting a new headunit in. You'll probably have to get a proper set of removal keys from ebay, just type "VW radio removal key" into ebay. Then you'll have to yank at the unit to convince it to come out and hopefully don't snap a clip.
                But in saying that, you really shouldn't have to, just try a few more dealers before you yank it out and potential damage the radio cage.
                  Sorry I took a while to get back. Managed to get radio out without breaking it. Used 4 nails the same size as the hole and out it came. Thanks again for your help.
                    we got the radio code for the 98 polo just via rego.
                    sounds like someone was being lazy there...
                    Bora gone
                    Vento VR6
                    MKIV GSW TDI
                    7P Touareg TDI
