Fixing an electrical problem
  • Fixing an electrical problem
    Hey everyone
    Ages ago, (I have no idea where), I remember reading that if you disconnect the positive and negative battery terminals, and then touch them together for a few seconds, that it will fix some electrical gremlins?
    Just wanting to know if anyone has done this? and will my car explode? haha
    I've got a problem with my auto up/down function for my windows, but it seems to come and go. So thinking about trying this?
    Also, on the topic of disconnecting the battery.. removing the terminals and then reconnecting after about 10minutes is how you reset your ecu right?
    Thanks in advance!
    Mitch
    www.mhemming.com
    i was told to disconnect the battery for 15min or so and it would reset some things.
    regards the windows, there is instructions in the manual on how to reset them.
    it involves winding them up, then doing a few steps using the door lock via the key, but I forget what they are...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      pretty sure I dont have the car manual lol
      Might get googling to see if I can fix it
      www.mhemming.com
        I have read the same thing as well. While chasing down some bugs during my engine conversion, I gave it a try.
        Dunno if it fixed anything, but it didn't kill the car, or the ECU.
        My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
          ahhh.
          ill try grab a photo of it when im in the garage later.
          seems to get asked a bit so ill add it to the stickies once i do
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            battery reset does fix stuff some times especially with the newer cars out now with so many ecu's etc... wouldnt think it would cure your windows but worth a try. remove both terminals from the battery then hold them together for 10 mins and then back on again.... to reset your windows either use the key in drivers door... turn to lock and hold in that position until all windows go to the top then turn to unlock and hold they will all open... this should return your 1 touch up down from the switch...if not hold each window switch until fully up..release then press up again for 2 seconds and then fully down.. release then down again for 2 seconds... should work..... is it just one window you have issues with or all 4?? ..VDUB.....
            BRISBANE / GOLD COAST
              Haha sounds complicated
              But I'll give it a go
              Currently only my drivers door has auto up/down
              Passenger only auto up
              And rears have no auto
              So I'll disconnect battery and then try reprogram my windows using key
              Do you start with windows down or up when locking the car?
              www.mhemming.com
                windows down x4 .. then lock with key... might not have auto up in rear but passenger should.... does auto up on the LHF window work from drivers side switch?
