So, I haven't had much time to try and work out what I've done, but I have started getting a little bit of a knock from the front end over bumps.
Last year my sway bar link came undone and was knocking on some bumps, its a similar noise, so I jacked the car up on Monday arvo and gave the sway bar link a good push and shove, nothing. But, when I turned the wheel against the gearbox (ie, just turned it while it was jacked up as much as I could) I noticed the engine moved (rotated) slightly front and back. Now, I can't be certain, but it seemed to move more than it has in the past and I wasn't giving the wheel a hard time, it was just a leisurely rotate.
I can get under and check the dogbone - I did replace that last year. Its a similar kind of rotation as when the dogbone was out. But, what else can I check?
Thanks guys,
Christian
Thanks guys,
Christian
