Hi Everyone,
Our Mk IV GTI stalled and could not be restarted this morning while backing out of the driveway, symptoms are:
-Warning lights showing on dash regardless of key position (key in ignition or removed). I had to disconnect the battery to stop it running flat.
-When turning the key to start the car, there is no "spring back" at the starting position, and no cranking.
I'm guessing the ignition switch has failed, can anyone suggest any options for us? I would like to pull the key barrel out and maybe lube or otherwise repair the ignition switch? A small amount of research on the web suggests pulling the steering wheel off to get access to the switch, does anyone have experience in this?
At least it happened at home and not on the motorway or in the city somewhere, so no tow required.
Any help would be much appreciated!
