After having the bolts in the peliquin diff let go and finding out that they originally had the wrong ones supplied I had the gear box case replaced and new ARP bolts installed so happy days......
Not quite because round 2 just started.
Most of the gear box oil jumped out the other day and on removal of the gear box discovered the lovely hole in the bell housing which is the tell tale sign of diff bolt troubles
Decided to split it this afternoon when I got home from work and this is what I found.
Hmmm whats all this shinny silver stuff
The hole from the inside of the case
Im sure something is missing
Oh wait there's the missing bits
oops
My spedo stopped working the other day and here I was thinking it was the sender unit (this is the gear the speedo runs off)
Do i put it back together or bin it and start again......
So next step ? not sure
+ hole in the case i can fix no problem
+ I need a new speedo gear and bit that goes to the sender unit
+ New bolts to hold the final drive to the diff
+ New clutch as the one in it is soaked in oil
Anyone know if I can buy the parts I need ?or where to get them from ? or Im almost in the mood just to send it to someone to sort it out so all I have to do is whack the box back in.
oops
