Running Problem, Loss in power, Rough idle, Shaking etc...
Ignition control module for sure. Lack of air flow has killed it. If you have a multi meter, jumpers and a 1.5 volt battery you can bench test it.
If it is dead driving around will kill the o2 sensor and maybe the cat also. Spark plug on dead cylinder, probably cyl 3, will be in bad shape from all the excess fuel also
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Speaks the voice of experience....... Got a link to the test for him?
Generally middle pin on 5 pin side is ground, put voltage on pin 1 measure resistance on pin 1 on other side repeat for each cyl. All should have a similar value. If one is way out you know its rooted. There is another thread on how to fix the thing also.
Another thing to try is removing the connector from each coil pack and see if it makes any difference.
MK4 GTI - Sold
I just watched your 1st video. It sounds just like mine did when it died, like a subaru, all too familiar.
I really do like the flutter sounds you got, what DV are you running ?
If you want to keep that air filter you will need to mount your new ignition module onto a big heat sink.
And as you live near the border remember that filter is illegal in NSW.
MK4 GTI - Sold
