A few questions :)
This topic is closed.
  • A few questions :)
    Hey guys I've noticed recently when driving at night that my a/c controls are not backlit.... Is this normal? And also my cigarette lighter thing is broken, could this have anything to do with it if they should light up?
    Thanks, Mac
    2014 Golf GTI PP - Pure White
    Hi there, the fuse for the cigarette lighter also covers the backlighting for the A/C controls. The fuse has probably blown, and will require replacing.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Sweet thanks man will check that tomorrow
        just the a/c button? Or all the dials and fan controls?
        the light out on the ac controls could just be the globe. If u have the older manual controls like me. Itd behind the fan speed control.
        From memory you turn it to vertical and can pull the whole switch out, but dont quote me on that!
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          Ok thanks will try that as well
            One more question, which fuse would be blown and where could I find it, and also which fuse could I use to test it?
              The fuse panel is on the end of the dashboard inside the drivers door. You have to pop off the panel cover, pry off using the car key in the slot.
              There is a card showing a map of the fuses. The map is a mirror of the panel and can be confusing.
              Fuse 41 15Amp is the cigarette lighter. Colour code for 15 amp is BLUE.
              Fuse 27 for the rear wiper is 15Amp also, you could use that to check.
              Don't use the fuel pump, fuse 28, you don't want to blow that and get stuck.
              MK4 GTI - Sold
              MK5 Jetta Turbo - Sold
                Not sure when they changed over, but or old 2004 Golf had LED illumination. Nearly cried when I was quoted $130 (trade) for a new control panel to get the lights working again.
                '01 Beetle 2.0
                  Thanks heaps really helpful will check that now
                    It was the fuse thanks for all the help guys will just have to buy a 15 amp fuse
                      ouch! I THINK it was with the rest of the changes. 2001.5 i think was the year.
                      dont ever worry about going out and checking the manual or walking out to the car on a cold rainy day to check things! Just ask JustCruisin!
                      Bora gone
                      Vento VR6
                      MKIV GSW TDI
                      7P Touareg TDI
                        Turns out that it only fixed the cigarette lighter and the fan control etc still don't light up will have to see how much it costs and decide if it's worth it (although hopefully my warranty will cover it )
                          Just to make sure, I'll ask the obvious.
                          Do you only expect the climatronic to light up when the headlights are on ?
                          MK4 GTI - Sold
                            The rotating bits. They should light up right? I've got a standard 2.0 and I find it almost impossible to turn on the demister and stuff at night
                              I've got a 2.0 with the rotating knobs and stuff to adjust the air con temp. etc and was wondering if this had lights because I've noticed at night that's it's almost impossible to find this to turn on my demister and adjust the temperature etc. Is this part backlit (normally)
