Hey everyone. What should the stock boost be on a AWU engine? Our beetle hits .6-.7 for a second then drops to .5 til redline. Is this normal?
Stock boost level?
That would be about right, small turbo gets a bit wheezy at the top end. You'll get 1 BAR or just over chipped up.
The downpipe isn't that high flowing but I don't think too many cats have become blocked.
I'm running out of options now, spark plugs/coil packs replaced, bypassed the n249, hks ssqv in the mail(but I've blocked off both pipes and the vac line for now), dump pipe in the mail,
Is there any common boost leaks?
My wife is getting very angry now and I need to find the problem before she burns the car. Getting out of a 2000 celica into the turbo beetle was a bad choice with the major power drop I think. I should have bought her a v8 so she could keep the power.
If there was a boost leak the ECU would most likely have picked it up. Have you had anyone else drive it? The boost you are reporting, what gear are you checking it in. You can't really use 1st or second, as the car accelerates too fast and ingests the boost as quick as the turbo produces it.
Running it up a hill in 3rd or 4th is a better way of checking the peak boost.
Why not give Jmac on here a call and see if he can check it out for you. Get the smoke machine on your engine to see if there are any boost leeks, and run a real time diagnostic check. Jmac is on the south side of Brissy and not far from Ipswitch.
im going to see jmac next week, and the miss has been there since we bought the car.
there is a major power difference, the celica out ran ve ss commodores on the highway easily and the beetle cant even out run a lancer. like i know the power figure is smaller on the beetle but with it running like it is its just making itself look worse.
Fixed plenty of exhaust blockages, it will idle "ok" then when you accelarate the biscuit in the cat blocks the hole off, if the cat was blocked you would probably notice it revving it up though. Sounds like your air mass meter is lazy. On a boosted car that can be checked with measured values, better still Scope it. Just fixed an audi with no fault codes but drinking fuel and runnin crud, no fault codes and all looking well. Cant stress enough that scanners even VCDS are good but they are only the icing on the cake. Oscilloscopes just dont lie periodOriginally posted by lilcrash View PostOk I just thought it might have been a symptom of a broken n75 to have a 1 second spike. Anyone had any issues with exhaust blockages?
JmacAlba European
