urgent help needed
  • urgent help needed
    ok so i need some help i have TA technik coilovers and with the fronts they hit on the inner of my wheels how can i fix this and has any1 else used ta teckniks before...
    Wheels spacers? if so what is the best size for a golf
    Yip, answered your own question, spacers will be the go. Get a wheel on if you can and measure from the outside of the rim to the outside of the arch, thats how much room for spacers you'l have, just take a few mm of so the wheel goes under the arch.
    Pretty sure Tim at Dub Addiction sells em, you'll need longer wheel bolts too
      ok ill check dub-adiction out bookmarked for good reasons lol. they said the coilovers were to suit mk4 golfs dnt know y i would have this problem and i only have 18x7.5" with original offset
      dub addiction must be down
        what specs are your wheels (offset and i see 7.5 for width)
        I have those coilovers in my bora, are they hitting on the strut or the coils/springs?
        I had big problems with the offset of my wheels (ET45) on a 8" wide rim.
        spacers will be the way to go most likely.
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          pretty sure they are et45 and its hitting on the spring adjustment spindle
            if thats the offset you'll just have to wind them up so the ring is above (or close enough to) the top of the tyre, until you get spacers.
            IMO, spacer size. 15mm will get the rim outside the line of adjustable nut, but tyre bulge can hit... what size tyres have you got? 20mm should make tyres clear even with 225 wide tyres (im guessing thats what you have..)
            Do you have your stock wheels still?
            Bora gone
            Vento VR6
            MKIV GSW TDI
            7P Touareg TDI
              yeh still have stock wheels and yeh have 225 wide tires on there how did u know
                im good haha
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                  im good haha
                  or it's the size we all have hehehehe
                  2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
                  MY15 Golf Wagon Comfortline
                    speak for yourself, 235s and 265s lol.
                    with et45 on the wheels u can still do 12mm up front and up to 22mm on rear for spacers.
                      thanks fuzion thats mainly the imformation i was after 12s or 10s on the front will do it i think
                        I meant to say that is generally the stock width
                          12s or 10s on the front?!?! inches wide or mm of spacer?!?!
                          87' MK2 GTI
                          13' MK7 TDI
                            spacers lol. my god 10 inches even on stock hieght will be poking about a inch or more on a mk4
                            Bora gone
                            Vento VR6
                            MKIV GSW TDI
                            7P Touareg TDI
