I recently had a gear box issue which took the car off the road for a little while...... seeing it was off the road i put in larger injectors, larger MAF and changed the software. Since getting the car back on the road Ive had a few issues with how its been running, with alot being due to vac/boost leaks.
I have sorted all the vac/boost leaks but the car still plays up a little , so im at the point where i need some other opinions on what it could be.
The issue i am having is that the car is missing @ cruise .....under load its fine no problems and idle is fine, but when you are cruising along it will miss every now n then and it seems that the throttle when lightly touched provokes the same response.
So throw some suggestions at me what i should be looking for as im at the end of my knowledge.
I will add that i only have a V-checker pro and no access to vag-com.
any more suggestions on what to look for .
