hey, just seeing whats the best way to take off your rear tail lights? thanks
help- rear lights
um.... undo the bolts holding them in
What model is it? I have a Mk 4 Bora and theres three bolts holding each light in. Undo those and they pop straight out
Project Hairdresser car DIY build has begun...
'96 Mirage Track car: BC RM Coilovers, 294mm Galant VR4 Brakes, 5 stud conversion, 16x8 Forged Rays MS01S, UR 23mm sway bar, UR Strut Braces, Evo 5 Recaros, MR Lancer electrics interior conversion, Engine + Exhaust in the works
both the bora and golf have three bolts holding the lights. you need an 8mm socket to take them out. bora is a bit more difficult due to the lack of space, so if you don't want to lose your socket insideOriginally posted by BI65ND View Postum.... undo the bolts holding them in
use a spanner instead
hope this helps
'01 VW Bora V6 4motion - gone
17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
One light on the Golf has a weird spike on one corner too.
The corner of the light can snap off if you pull it the wrong way too hard.
Look for a DIY on vortex or ukmkivs for some pics.PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
