on my mk4 on the r/h/f door the courtsey light isnt working and i've switched the light assembly from the other door to the problem door and it has'nt solved the issue so then i started testing the wiring to see if had power to the light assembly which i found that i did but i dont know what else it could be maybe possible break in the wire im not to sure
Courtesy Lighting Not Working
I assume the globe is ok....
Make sure there is no part of the light assembly touching anything and grounding out.
Test the actual switch to see if it works.
Don't reckon it's the light. If you have central locking, unlock the door, open door does the car try to relock after 30 seconds or so ? If it does, it means your door lock module is faulty and the car doesn't know the door has been opened or open. There is a guide to repair your door lock module on Vortex do a search on there, or try the FAQ forum for mkiv's but the actual repair thread is buried somewhere there, intense though, so you may just want to purchase a new or refurbished one.Last edited by qsilverza; 15-07-2009, 04:09 PM.Audi B4 80 Q V6'94 Race Car !! KEGGED
Audi B4 80 V6 Avant'94 Only one in the country that I know of !!! KEGGED
Subaru Forester XT'06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
--VW Bora V6 4mo'01 Gone
it has 2 do with the solder cracking on some sensors one of my rear passenger doors does the same thing. Need 2 take the thing apart and resolder 2 resolve the issue.1999 Golf GTi - SOLD
2005 Golf GTI (2 Door) - SOLD
2014 Octavia RS400 Combi
1997 Golf GTI (Daily/Track Hack)
that happened to me yesterday! i was inside the car and what i've found out is that when it does that you cant open the car from inside. i tried pulling the door handle - nothing, press the unlock button on the door - nothing. the only way to open it was with the keyOriginally posted by qsilverza View PostDon't reckon it's the light. If you have central locking, unlock the door, open door does the car try to relock after 30 seconds or so ? If it does, it means your door lock module is faulty and the car doesn't know the door has been opened or open. There is a guide to repair your door lock module on Vortex do a search on there, or try the FAQ forum for mkiv's but the actual repair thread is buried somewhere there, intense though, so you may just want to purchase a new or refurbished one.
'01 VW Bora V6 4motion - gone
17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
Vwvortex http://www.vwvortex.com
http://forums.vwvortex.com/zerothread?id=1835863 - MKIV FAQ
http://forums.vwvortex.com/zerothread?id=1542461 - Door Lock Module
Originally posted by Jof View PostSorry for the ignorance, I have the same problem with the drivers door, but what/where is Vortex?Audi B4 80 Q V6'94 Race Car !! KEGGED
