Help please - Shudder when breaking
    Well mine are OEM..
    Can't wait until the problem is fixed though, it'll be like a new car then.
      got my discs and pads done:
      Durid rear brake pads - $86.70
      Zimmerman rear disc rotor - $121.00
      $415.40 all up!
      drives well.
        A little off topic here, but can the R32 rotors etc be fitted to a standard Golf, or is it not worth the hassles?
          I don't think the extra braking would be worth the expense. You would be into a set of 16 inch wheels, if not 17s just to go over the discs. You'd have the cost of the discs, pads, brackets and possibly the calipers too.
          I reckon the std 288mm brakes are adequate for the car in std form.
            I'm pretty sure the Audi TT brake rotors will fit without significant changes.
            2000 Mk IV GTI
              Brake rotors
              Hi all,
              A few weeks ago my brakes started to shudder and vibrate up through the brake pedal and steering wheel as well...great I thought, rotors machined/replaced and pads too.....and the pads show little or no wear.
              Then a funny thing happened...it rained.
              I drove around in the rain for a couple of days and since then the shudder/vibration has almost gone...certainly gone enough for me to not consider doing anything with it just yet.
              I am wondering if driving around in the rain could have cleaned/dedusted a lot of the braking components / abs sensors etc?
              Could the shuddering have been caused by a build up of brake dust / glazing of the pads or something else?
              I could have sworn it needed the brakes doing...now I'm not so sure.......
              Has anyone else come across this before?
              2010 90TSI Manual / Comfort Pack / United Grey
              RICE - Leave the useless wings to the Penguins...
                Need 17s minimum, potentially 18s.
                322mm fronts are a pretty beefy upgrade over the 288mm stock setup.
                Nothing to see here...
                  Actually they're a 334mm rotor and I don't think I've ever seen them fit under a 17" rim. I know people have had issues with certain 18" designs that won't fit over the brakes. Also if you have a puncture you will need either the same rim or an Audi 8L S3 space saver which will only fit over the rear brakes and not the fronts.
                  Yes you will also need the full setup with Calipers as well as rotors and pads. None of which are cheap. From VW Australia you're looking at $500+ per front rotor and over $300 for a set of front pads. No idea on the cost of the calipers.
                  When the dollar was much better I got both rotors delivered from the US for less than $500 and EBC red stuff pads front and rear for about $300 from memory. Slotting the front rotors cost me about $100 locally.
                  Cheers,
                  Trent
                    Hmmm, I've been told (I'll have to confirm, since I have 17s coming) that the OEM 17" Bora Sport V6 4Motion wheels will fit over the R32 brakes. I believe the rears on the R32 are the same as the rears on my Bora V6 4Motion too.
                    I'll have to get all this confirmed!
                      Yeah I'm not 100% sure on it there mate, DUB20V has some knowledge about it as well due to him having that setup before he went to the Porsche brakes. Might be worth giving him a PM. The rears are definitely a lot smaller and will have no issues at all.
