My 01golf gti has started to shudder really badly when the breaks are applied. You can feel it coming through both the pedal and the steering wheel. At its worst when you have been breaking and hit about 60-70 klm Any help would be very greatly appreciated. Cheers
Help please - Shudder when breaking
Originally posted by ntails View PostMy 01golf gti has started to shudder really badly when the breaks are applied. You can feel it coming through both the pedal and the steering wheel. At its worst when you have been breaking and hit about 60-70 klm Any help would be very greatly appreciated. Cheers
If you need to get new discs, don't go through VW, you will pay too much. DBA and RDA do brake discs for the MK4 Golf, and are alot cheaper, but may last a bit longer. And you will need new brake pads too after doing all of this, as the old pads will have bedded to the old discs, and you won't have the same braking efficacy."If can't get behind your troops, feel free to stand in front of them..."
Originally posted by BoraV64Msilver View Posti've got the same symptoms when i slam on the brakes - with ESP turned on.
Then turned off i dont get the shuddering, but i skid.
It's always been like this so i assume thats the way its ment to be.Nothing to see here...
Be careful if your going down the machining road, especially on all German car's with soft disc's.
They will machine up ok & will last for alittle while, but where it was warped, they tend to also get hotspot's right through the material, which leads to the shudder coming back over time
If you just machine or replace the disc's, the pad's also develop hot spot's them & the result will be the same over time
My advice. Replace the pad's & disc's.
Originally posted by golfworx View PostBe careful if your going down the machining road, especially on all German car's with soft disc's.
Originally posted by FknDubbin View PostHe speaks the truth. When i was working at VW we never machined discs and as far as i can remember, VW actually specifies no machining of discs.
And Ive seen why , $4k + worth of damage ! and they were luckyBug_racer supports the rebellion of the euro revolution
Have to take them back.. It's gotten better at lower speeds but it's really bad at higher speeds (70km/h +)Last edited by maca; 14-09-2008, 09:03 PM.2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Originally posted by maca View PostI've started to have this problem as well.. Just after I got new brakes!
Have to take them back.. It's gotten better at lower speeds but it's really bad at high speeds.
Definately rotors then. I priced them from supercheap today, and it seems a bit steep to me! (and i'm not even sure what model rotors are for mk4 2L... there's a different listing for american 2L Vs. mk4 from 98-01... confusing much?
Either way, standard DBA rotors are about the $90 mark each, give or take $5; slotted are a joke at about $210 each, or x-drilled for $250! Prices for slotted or drilled seem a bit bloody steep to me!
