Mk4 2.0L Engine Stopping - ECU Fault
  • Mk4 2.0L Engine Stopping - ECU Fault
    Hey Fans,
    I purchased a MK4 for my son and it has been great until the engine just quits . It will start again when cooled a little . drive for a bit , then stop again . I plugged in handy dandy code reader expecting crank angle sensor or coil pack and it reported no faults . However , we trouble shooted on the weekend by letting it idle until it quit , then plugged the reader in . It could not communicate with the computer . After 10 mins , communications were re-established and the engine would start again.
    After consulting the Google Gods , it seems that the ECU may be faulty ( random engine stops and inability to connect a reader when this happens ) .
    Any input here for MK4 owners ?
    Also purchased VAG-TAcho from ebay , but it will not connect to the cable and software had virus.
    Any recent recommendations for a VAGTACHO , as I know ill have to re-programm the IMMO if I need to swap the ECU.
    Or... Am I up for $299 US for the Rosstech unit ?
    MK4Dad
    PM IanGPonzaga on here, he'll be able to give you a hand with any programming.
    2004 VW Bora 4motion | 3.2 Swapped - R32 Trimmings | BBS CH | Forever fixing this bitch
      Have you had any luck mk4dad?
      My GTI has the same issue and a genuine new ECU + labour is getting close to 50% of the value of the car.
      79 MK1 GLD
      03 MK4 GTI
      94 993 Carrera
        It’s alive! (?!?)
        I might have fixed the issue with my GTI. I bought a used ECU and physically transferred the immobiliser chip.
        The car has been idling for about an hour since and seems fine. No error codes and no stalling.
        79 MK1 GLD
        03 MK4 GTI
        94 993 Carrera
