So i have a 1996 1.8 mk3 golf CL and just recently my idle has either been high at 1200-1600 rpm or really low at 500 rpm and about to stall. This only occurs when it's warm and the engine has had a little bit of load applied. I've checked and replaced old vacuum lines and that word for about 30 minutes and it started acting up again. Just yesterday when sitting at idle it was going from 500 rpm up to 1500 rpm, and this kept happening until I switched the car off for 2 minutes and when I started it up again it was normal.
I'm after any advice I can get on what the problem is. Thank you in advanced for any help or advice you may have.
