Brake Master Cylinder R&R......whats the pain in the arse rating?
done and dusted today, if I had of been game enough to pry the plastic reservoir off before I removed it, it would have been a piece of cake.
with the reservoir in place it was difficult to access the hard line closest to the vac booster, but not impossible.
didn't bench bleed, as I wanted to install the master and then attach the reservoir, bled up fine anyway.
took the opportunity to replace a couple of rubber vacuum lines while I was in there.....from start to finish in about 4.5hrs which I was fairly happy with, as I had cleared 2 days in case it all turned to a big pile of ****.
I ended up getting my mechanic to replace the brake lines and bled the brake fluid on the Vento yesterday for me even though it should be a job I can do myself because I am time and workshop poor.
