Hey guys so my central locking decided to stop working, i press the button and you can hear the motor moving in the door but nothing happens, any suggestions? or anywhere i can get it fixed?
Central Locking
The system has a pump and air lines, if the pump is running there is a leak/break in the air line.
If it was the pump the fix is pretty quick and simple, if it's a leak it means checking all the lines till you find the problem.
What a lot of people do is to replace the air system with an electric system which also means you can get remote central locking
At the end of the day the actuators are cheap, it's the install that will cost you (unless you DIY).
Originally posted by The_Hawk View PostThe system has a pump and air lines, if the pump is running there is a leak/break in the air line.
They use air lines?? That seems very strange to me? wow
it's a vaccum based system I believe, hence the air...
Yep, the cruise control also uses a vacuum system as does the re-circulate flap for the AC system... guess what parts are on the commonly broken list?Originally posted by Jarred View Postit's a vaccum based system I believe, hence the air...
The AC flap can be fixed with a relatively quick and easy work around (which still uses the air system), the central locking can be done with cheap actuators, the cruise... well... most people don't try and fix it. It's a shame that since all we are talking is accelerator control that no-one has built an electric motor/actuator to pull the throttle cable (like conventional systems) or even a software hack to electronically control the throttle body (assuming it can be control to open far enough).
When it comes to fixing your system it's worth a poke around the door lock assembly and the pump assembly as there is a good chance one of the joints is gone. After that your left with the lines themselves under the carpet...
As for 'working pump'... Anyone know if when they go they stop entirely or if they 'slow down'? Just wondering if while it's making noise it's actually still good or not?
