280 - 288 mm brake conversion
  • 280 - 288 mm brake conversion
    I have an early model vr6 and am pondering upgrading the brakes to the later larger version. Am just looking for advice as to whether or not the calipers that suit the 288 mm discs will bolt up to the stub axles already on the car or if they will need swapping over or adapter plates? ? ?
    Cheers all
    Need calipers, carriers, rotors. Pretty sure brake lines were the same
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
        Lines are different, the 288mm take banjo bolts. 280mm screw into the caliper.
        '95 Golf VR6 Colour Concept
