G-8VXWWTRHPN Things that go bump - VWWatercooled Australia
Things that go bump
  • Things that go bump
    Occasionally when I go over a speed bump the front will make a clank sort of like the clank of a jack hammer. I don't think this is normal and it sounds like whatever is supposed to cushion the bump or something is missing.
    Not too sure what it is.
    Past - '95 VW Golf MK3 VR6
    Lower control arm bushes and strut top bushes.
    Also, don't rule out swaybar bushes and end links.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      shocks?
        hmm, when I had a service they did look around the control arm area, they didn't find anything apparently. (but I didn't mention anything to them either)
          I'd suggest checking these too. Make sure everything is tight
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            Can I find it in the Bentley Manual?
            Or are there any good links so that I can read up?
              What's this supposed to be and should I be worried? (looks to be just a sleeve on it but still want to be sure)
                This is my right side top.
                  Underside rear left.
                    Torn CV joint boot......get it replaced as soon as possible or CV joint will be next on your shopping list.
                    Calling NSW Mid North Coast VW Enthusiasts - Click Below
                    Mid North Coast Dub Club
                      Is this something that would have been seen during a major service? because they didn't mention it to me...
                      By the way, is this outer or inner? (sorry if noob)
                      Also, where can I get this done ASAP?
                        Literally doing this myself within the next few weeks. I had a pre roadworthy inspection and my mechanic said its a RWC requirement :/.
                        2012 - Tiguan - 155TSI - DSG - Black
                          Yep they should have spotted that, looks like drivers side inner to me, and no idea where abouts to get it done where you are but goes without saying not at the place that serviced it
                            I have been in contact with a place close to work, said they'd do it for $188 (all up). I think that sounds reasonable?
                              That sounds very fair! I'm doing it myself and it costing me $90! So $100 labour to save yourself a few hours is good!
