Hay guys looking to see if anyone can point me in the right direction or give out any pointers. Currently have completed an auto to manual converstion in a mk3 vr6 I'm currently having issues starting to car. Could anyone give any hints out to what I have to do?
Vr6 auto to manual help
changed the ecu to a manual one? Imagine trying to start the car not in Park mode on an auto. Won't work. If ecu isn't receiving that then it wouldn't start I'd suspect. Obviously also the manual starter is different to the auto one. The more information you can give us on what you've done and what it's doing the more likely someone can help you
Hay when you go to crack does nothing no clicking sound from the starter motor. Im running the manual starter motor. I've got a donor car which I have taken all the parts off. I've plugged the ecu off the manual and same thing happens also comes up with a error code on Ross tech that engine start is blocked by the imboliser. I've also disconted the auto ecu dash doesn't display it being in park.
Read this: VWVortex.com - 020 Manual Swap FAQ/DIY
If you still have the auto wiring in there, you may have to jumper the 6-pin plug that used to sit below the battery on the transmission to make the car think it is permanently in neutral.Past: '77 VW Golf GLS Mk1 3-door, 2 x '95 VW Golf CL Mk3 3-door, 2015 Mk7 90 TSI Manual
Present: 2018 VW Golf GTI Original Manual Mk7.5, 2006 VW Caddy Life Camper
