Went on a drive up Mt Cootha tonight and it seems the clutch has thrown the towel in. It's a bit of a surprise considering its only about 20,000 clicks old... And my mechanic had the box out last year and didn't think it was worth replacing?
I don't really drive the car super hard, usually double declutch on down changes and never drop the clutch so I personally dont think its had that hard of a life, especially compared to some of my mates hyundais and corollas...
But a quick run down:
Came into a corner, depressed the clutch to change out of second into third.
1) Pedal went down fine.
2) Gear stick wouldn't come out of second (felt as though the clutch was still engaged)
3) clutch pedal seemed to stay jammed to the floor
4) drove it into the closest clear dirt spot on the road and managed to get the pedal off the ground and it returned to the normal spot.
5) gear stick still stuck in second and pedal will depress loosely to 3/4ths of the way down and then it gets really tough and spongy (feels like a brake pedal without booster).
6) Managed to get gear stick into neutral by turning over with starter motor.
7) Car still wont start and there appears to be a grinding noise coming from the bellhousing and you can feel it in the clutch pedal....
My novice diagnosis is that a bit of the clutch has snapped off and is now jammed between the pressure plate and flywheel making it grind and preventing the car from starting, even when in neutral.
I feel like it would still start in neutral even if one of the clutch cylinders had gone?
Anyway, would love some advice on the above and if confirmed that its a destroyed clutch, what kit I should be going with!
Cheers,
Max
Cheers,
Max
