This is a sticky topic.
  • Comment
    • look at the wheels on the white one at the end ^^^^^ :O
      '94 3dr vr6
      • too good
        '94 3dr vr6
        • what are these wheels i likey
          Last edited by mk3pete; 09-09-2009, 11:37 PM. Reason: hmmm noob didnt know how to copy image
          Wide Steelies For Sale
          http://www.vwwatercooled.org.au/foru...ies-76972.html
          • Widened New Beetle steelies!
            Present: Mk3 Golf variant.
              what do you mean by widened how is this possible?
              • Machine out steelie centre, weld into new (and wider) barrel!
                • Pete, Ray's rocking widened steelies on his GL!
                  I admire the courage of those that drive with such small amount of tyre clearance. I also hate oz roads.
                  • fair enough then im disappointed now
                    to be honest i wouldnt be bothered to go to these lengths to put steelies even though they look awesome
                    • Originally posted by b0k1 View Post
                      has to be one of, if not, my favourite Mk3 of all time... So simple, yet so dam cool!
                      • Engine:
                        R32 Motor
                        Full R32 Harness wired for MK3 from headlight to taillight
                        Turbo Kit
                        -Eip Manifold
                        -Eip Downpipe
                        -Lower Compression Head Gasket
                        -Unitronics 630cc File
                        -630 Injectors
                        -Audi MAF
                        -Upgrade Fuel Pump
                        Crack Pipe
                        Raceware Head Studs
                        Tranny:
                        02J Tranny w/peloquin
                        6 puck clutch
                        Short Shifter
                        Suspenion:
                        Air Ride Suspension
                        Poly Bushing
                        Wheels:
                        17x8.5/9 Carline CM6
                        205/40/17 Falken 512's
                        Brakes:
                        Cross Drilled All Around
                        R32 Front Brake Set-Up (Still need to get that)
                        All New Brakes Lines
                        All New Pads
                        2.0 Master Cylinder (Non ABS)
                        Interior:
                        Sparco Racing Seats/Harness
                        Sparco Steering Wheel
                        False Floor
                        Mk4 Dash w/r32 cluster,climatronic, lighted jetta vents, etc
                        Dynamat Floor
                        All black pillars, and headliner
                        R32 Shift Knob (5speed version)
                        R32 Pedal
                        Mk4 Euro Headlight Switch
                        Roll Cage
                        Exterior:
                        Shaved Front Euro Bumper
                        Rear Euro Bumper
                        Pull Arches
                        Boser Euro Hatch
                        Sleepy Boser Hood
                        Shaved Antenna
                        Shaved Rockers aslo made to one piece, no more line coming from fender
                        Shaved Bay
                        Notch Frame
                        Audi A6 Door Handles
                        Pzwo Mirrors
                        Jetta Ecodes w/Hids
                        All Red Tails, cut to match boser hatch
                        Badgeless Early Vento Grill
                        Repainted Black
                        • Originally posted by WABIT View Post
                          Engine:
                          R32 Motor
                          Turbo Kit
                          -Eip Manifold
                          -Eip Downpipe
                          -630 Injectors
                          -Audi MAF
                          -Upgrade Fuel Pump
                          Crack Pipe
                          Raceware Head Studs
                          Tranny:
                          6 puck clutch
                          Short Shifter
                          Suspenion:
                          Air Ride Suspension
                          Poly Bushing
                          Wheels:
                          Brakes:
                          All New Pads
                          Interior:
                          False Floor
                          Dynamat Floor
                          R32 Pedal
                          Roll Cage
                          Exterior:
                          Rear Euro Bumper
                          Pull Arches
                          Boser Euro Hatch
                          Sleepy Boser Hood
                          Shaved Antenna
                          Shaved Bay
                          Notch Frame
                          Pzwo Mirrors
                          Jetta Ecodes w/Hids
                          Repainted Black
                          yes love this
                          got a bit of inspiration from this to do mine as well as few others incuding some from this site
                          (]/_ O _____ O _\[)
                          "'(O8o)=\X/=(o8O)
                          [__|========|__]
                            Engine:
                            R32 Motor
                            Turbo Kit
                            -Eip Manifold
                            -Eip Downpipe
                            -630 Injectors
                            -Audi MAF
                            -Upgrade Fuel Pump
                            Crack Pipe
                            Raceware Head Studs
                            Tranny:
                            6 puck clutch
                            Short Shifter
                            Suspenion:
                            Air Ride Suspension
                            Poly Bushing
                            Wheels:
                            Brakes:
                            All New Pads
                            Interior:
                            False Floor
                            Dynamat Floor
                            R32 Pedal
                            Roll Cage
                            Exterior:
                            Rear Euro Bumper
                            Pull Arches
                            Boser Euro Hatch
                            Sleepy Boser Hood
                            Shaved Antenna
                            Shaved Bay
                            Notch Frame
                            Pzwo Mirrors
                            Jetta Ecodes w/Hids
                            Repainted Black
                            thats hot.............
                            White 95 vr6, colour coad, koni, neuspeed, 16 x 9, samco!
                            • Needs this kind of body though, and awd lol
                              • Perfection.
                                Please tell me there's a build thread.
                                [The black one.]
                                2000 Mk IV GTI
