I dont own a dremmel
Diesel Geek Shift No Longer in Production
They aren't all that expensive and are a very useful tool to have. The "Dremel" branded one of course is better, but if you want one on the cheap grab the Ozito branded one. That's what I have and it works well enough for the occasional use.Originally posted by MattyT View PostI dont own a dremmel
What I do *highly* recommend is that you buy the dremel branded accessory kit. Basically it's a box of bit you will most likely never use, but when you look at the price of cutting discs alone, the box is quite attractive and those other bits do come in handy from time to time.
every man needs to a dremel in his toolkit.
They come in handy for all sorts of things. Especially when you have to cut through a bolt in an obscure location!
FOLLOW US ON FACEBOOK
Side to side is also in now. It realyl doesn't take long to do, although it's in a bit of a tedious place to get at.
The end result. Yes it does reduce side to side, but not as dramatically as the front to back. It's easy enough to do anyway, but not something I would loose sleep over if you didn't put it in.
