Fuel pump for VR6
  • Fuel pump for VR6
    Hi all
    My fuel pump for my VR6 (1994) is faulty. Any suggestions for a replacement?
    I would rather not go to a dealership...
    Thanks in advance...
    If you want a second hand one, I am sure someone on here might help you out.
    I got a second hand one about 3 years ago from someone on here, still works fine
    MODS- TOO MANY
      How quick do you need it??
      Shop over 10,000 VW & Audi parts in stock for same-day shipment. Use our extensive online catalog to find the OEM and Genuine parts you need fast.
      Brand New pump is US$197.35 + shipping. Also if you located in Sydney, Golf Houso is lo0oking at a group buy (well ordering a bunch of stuff to save on combined shipping) in the next few weeks:
      I've just got stuff from them, highyl recommended.
        Thanks for the response guys.
        I use my car for work so I would prefer to get one locally ASAP.
        Are there any good VW parts shops in Sydney or Melbourne you could recommend?
          you can get one from euro car parts for around $400. sounds expensive i know. but cheaper than a dealer!
          FOLLOW US ON FACEBOOK
            Well express delivery from these guys was damn quick. I ordered at 2pm on the 4th and had my box by 11am on the 9th if that helps any...
              Sounds great. I could wait a few days.
              I'll call the local VW dealership Monday and see what they retail for.
              I'm guessing somewhere between $400 - $500...
              I probably order them from OS... I'll update this post when I know...
                I suppose it's really going to come down to the delivery costs since :
                US$197.35 = AU$221.45 + shipping.
                For reference I ordered the following and shipping was US $128.30, i'd have to guess yours would be less:
                Code:
                Order Summary________________________________________
                3 @ 0.11 ech	Sealing washer, 14x20mm, copper Volkswagen Golf
                3 @ 10.92 ech	Oil filter kit Volkswagen Golf
                6 @ 5.79 ech	Spark plug, NGK BKR5EKU. Volkswagen Golf
                4 @ 20.95 ech	Polyurethane bushing kit, rear upper shock mount. Volkswagen Golf
                2 @ 2.21 ech	Nut, strut bearing retaining Volkswagen Golf
                1 @ 93.71 ech	Ignition wire set, high performance. Includes 6 plug wires plus coil wire. Coil wire not required for models w/o distributor. Volkswagen Golf
                2 @ 7.50 ech	Cap, expansion tank Volkswagen Golf
                2 @ 43.58 ech	Expansion tank Volkswagen Golf
                1 @ 27.56 ech	Bushing kit, front control arm, polyurethane Volkswagen Golf
                3 @ 35.00 ech	Strut bearing kit, heavy duty. Volkswagen Golf
                1 @ 16.54 ech	CV Boot kit, for 100mm (3.93 inch) diameter joint Volkswagen Golf
                1 @ 17.64 ech	CV Boot kit, for 100mm (3.93 inch) diameter joint Volkswagen Golf
                4 @ 3.00 ech	Bolt, strut mounting. M12x1.5x58mm Volkswagen Golf
                1 @ 43.00 ech	Ignition wire removal tool Volkswagen Golf
                2 @ 17.09 ech	C.V. Boot kit. Includes new boot, circlips, grease, clamps, and axle nut. Volkswagen Golf
                __________________
                $607.84 SUBTOTAL
                Food for thought anyway.
                  Thanks... I'll keep you posted.
                  The part that failed is deep inside the housing. It a small electric pump. It works but sometimes you have to bump it to get it to run.
                  Would be great if you could buy just that part from VDO but...
                  Anyway... Thanks again.
                    Picked up a new fuel pump from Euro Parts in Adelaide today... $300...
                    Just finished fitting it.. All good.
                    I also got a price from the local dealership ...$920... For the same VDO item.
                    Can you believe that?
                      Yep, I believe it, Dealer purchases are a last resort.
                        only 300% difference???????????? hahahahhaha
                        good one !
