MK3 Random Thread
  • Um who?
    • calipers on the back only for weight saving?
      Bora gone
      Vento VR6
      MKIV GSW TDI
      7P Touareg TDI
      • Originally posted by HaydEn View Post
        8v turbo? Fuvk yeah
        *neuspeed supercharger you mean
        That's all you need for handbrakies!
        • ah damn, wish i knew about that Ray!
          '95 Golf VR6 Colour Concept
          • Did some calculating, With the tires and new rims they will fit out 5.2cm further then stock ET45 rims, so approximately 4-6mm poke from the guard. Getting excited now but still have to wait till the weekend to paint and get the tyres fitted before I can see if it's legal enough to run with.
            Mk3 2.0. Mk3 VR6 CC. Future Mk2?
            • Just curiously, do how often would you need to change the waterpump? And much difference between the OEM plastic and aftermarket metal impellers?
              • use genuine, that is all id say.
                mine had been replaced when I got it.
                not a blade left on the pump
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                  Im guessing it was a non genuine pump with plastic impellers?
                  • Anyone in the penrith/sydney region that has experience installing air bags free any time soon? Wanting to tackle this with someone with experience. I can bring beer. Cheers
                    • Originally posted by AKA VR6 View Post
                      Didn't you end up selling the kit?
                      Present: Mk3 Golf variant.
                      • How much would it cost for a workshop to do timing chains? Anything else that should be done while that's being done?
                        Past - '95 VW Golf MK3 VR6
                        • Originally posted by stefcio007 View Post
                          $3000 give or take a $1000. Cams if you want some gains, rear main, clutch, gearbox input seal.
                          Sent from my HTC_PN071 using Tapatalk
                          • Would change headgasket too while it's basically all apart.
                            Mine cost $1300 + $1650 for new motor + resale of car cause it's been rooted ever since.
                            • 3K for chain replacement!? Which workshop does chains?
                              • oh, I should clarify, not replace them, just re-adjust them or do they just get replaced?
                                Although I have seen (from online) that a lot needs to come off for it to be done so...
