Put approximately 4 hours in just today just searching everything for wheels and such. Considering even going for fake bbs's rs rims since there is such a little amount of nice fitting wheels I'm finding.
MK3 Random Thread
Originally posted by milan12 View PostCheck oil light flashed today... this can't be good..
Sent from my SM-N910G using Tapatalk
Easy to check if you have enough oil. If all good it's probably just a faulty sensor.
And if your pressure is going then you should be able to spot a leak.Past - '95 VW Golf MK3 VR6
I'll still check everything out tomorrow and see what it is. It might be the PCV valve that my dad snapped off last week....
Just happy because its getting a good service this tuesday anyway.
Originally posted by HaydEn View PostWhat if the oil pump is done?
Originally posted by milan12 View PostI checked out the oil and it seemed fine. I turned the car off, came back 8 hours later and drove home from work and nothing happened. Its bizarre.
There's a post on the net where someone had the light come on more often and it turned out an oil baffle had disintegrated and was blocking flow and reducing pressure. It could be many things.
Always good to have a good look, if you can find the problem yourself it saves having to pay the mechanic to try and find it, and their time is more valuable than yours.Past - '95 VW Golf MK3 VR6
Originally posted by stefcio007 View Postwell then you've got bigger problems.
I had my PCV leaking for a while, didn't trigger the light, just had oil sapping there and heating up, could smell it in the car. Unless something there was unplugged?
I'll change the oil tomorrow I think and will chuck in that engine cleaner stuff and see what happens. It could be a blockage or anything really. I just don't know really. It beats not trying though. Happy to cross the PCV valve and associated hoses of the list.
I admit, I am out of my element with VWs. More comfortable with Holdens but I'll give it a crack anyways.
Originally posted by daslow View Posthey, does any one know where the immobiliser is located in a mk3 golf? I can't find one and the scanner is reading a code for immobiliser. cheers.
It's normal for it to show up when the car isn't running.Past - '95 VW Golf MK3 VR6
