Engine cuts out in VR
  • Engine cuts out in VR
    My VR is doing funny things this morning. After driving for about 5 minutes, I noticed that the engine cuts out on full throttle. It has nothing to do with revs as it's fine if you don't floor it.
    It feels like it's being starved of oxygen like someone is "covering up" the air intake.
    If you keep your foot down, the car stalls, so all you can do is go easy on the throttle.
    Any ideas people?
    RIP Ruby Thunder (1994 VR6), now driving the GF's MK IV 1.6
    Hahahahahha!!!!
    You have discovered the VR6's anti-thrash mechanism
    You need to wait until the oil temp goes over 50c, then you can do whatever you please.
    Until then, if you hammer it the ecu will turn off 2 cylinders and if you persist it'll shut down the engine.
    I found this out when I tried to pass a truck once after just leaving my house
    Have repeated it several times since. Sneaky ecu!!!!
      Nah it was even doing this after a trip back to Nedlands from Osborne Park.
      This doesn't feel like it's on 4 cyls, this just cuts out.
      Not a happy camper...
      Originally posted by MattyT View Post
      Hahahahahha!!!!
        Never had an issue with mine even when cold.
          is the fuel pump noisy? If you can hear it then it may be due for replacement and starving the car of fuel. They seem to last about 150k - 200k kms
          FOLLOW US ON FACEBOOK
            I can't tell... the whole car is noisey.
            There is a new(ish) engine in there, only done 92000 kms. Not sure if the fuel pump is the same or what...
            Pity Joe is closed for the holidays.
              worn out spark plugs can do that to the car...
                Fuel Filter get it changed I had a similar problem where I was going full throttle at 5000rpms it cut out but the revs still went out!
                  Is it tough to do that yourself?
                    OK, I'm gunna get me a fuel filter and install it today. I noticed you have to remove some fuze and then try and start the car, followed by disconnecting the battery. The DIY I found also recomments removal of the back drivers side wheel, is this really necessary?
                      Removing the fuel pump fuse just means that theres no air in the system when u do reconnect it. Jack the car up and have a peep urself u should see the fuel filter pretty easily.
                        OK filter has been changed, but I experienced the issue again... maybe time to try new plugs and leads.
                          Plugs and leads are VERY expensive locally. If you afford the wait, try here:
                          Shop over 10,000 VW & Audi parts in stock for same-day shipment. Use our extensive online catalog to find the OEM and Genuine parts you need fast.
                          Might as well grab some OEM oil filters, sump washers and the lead remover tool while your there.
                          Check out my post here from when I was thinking of picking up all those parts:
