I just need to replace my sump gasket, I've got the new rubber gasket but I need a few tips from people who have probably done this a million times before.
I have the rubber gasket, is it better just to use that, or to use some sealant as well? If so what sealant would you recommend?
If you use sealant, how long do you need for it to set before you can fill it up with oil again?
What size are the hex bolts that you have to undo, and what torque do you tighten them when you do them up?
Any other tips would be appreciate, thanks!
