I know that putting a load onto your car, like headlights or power windows cause the revs to drop as it sucks power, but in my case, when the light and the blinkers are on while sitting at the lights idleing the revs dip in time with the blinkers. Bumping the revs up a bit by using the accelerator and the car seems to be making enough power to run everything.
No issues with power otherwise, starts fine, seems to charge the battery and everything else fine. Is this just a case of too much load for the idle revs?
I'm running a Pioneer headunit, Pioneer 200W amp and thats about it, but still more than stock.
I also don't have the idle stabliser, although I have been told that they usually get pulled out when they break as they aren't 100% necessary.
So is this the tell tale signs of a alternator on it's way out, or just not enough power at idle?
