Hi guys, I'm taking a shot on this and seeing if you guys have any info.
From what I've seen on the tex is that.
I'll need:
Upper timing cover
Cam sensor trigger (mounted to rear cam on top of cam gear)
Cam sensor
Coilpack and bolts.
ECU for OBDI coilpack
Engine harness
Things I'm not 100% on:
ECU harness.
MAF - early OBDI VR6's had the hot wire, then they went to thin film (still OBDI)
Basically all those things. Now, what I'm wanting to do is put a distributor-ed 2.9 into my coilpacked 2.8. Now by having that list is it simply as straight forward as swapping it all over?
Or could I put my 2.8 head onto the 2.9 block and avoid all of these problems?
P.s mods move if they feel it will get better responses elsewhere.
Thanks Hayden.
I'll need:
Upper timing cover
Cam sensor
Coilpack and bolts.
Engine harness
ECU harness.
Thanks Hayden.
