Hey guys my VR6 is ill and no longer wants to start, cranks but doesn't fire up ); Few months back I replaced my leaking heater core and thought it would be wise to replace my fusebox at the same time as my brother managed to make it melt itself away by plugging a torch into the cigarette lighter.
I've really neglected this as I've been busy with work so the time it took me to get the heater core out was about 3 weeks on and off (worst job ever). Before I replaced the melted fusebox I found that every time I started the car the fuse for my interior lights/central locking would kill itself. I've since replaced it and made sure I transfered every cable/relay at a time so I wouldn't screw it up.
I don't know if the top right red connections are in the right spot but I've tried different combinations to no avail.
Random unconnected stuff
Odd loose cable 1
Odd loose cable 2
EDIT: I should also mention the car seems to 'fire up' better when it's jump started but it never gets past cranking regardless.
As it stands, the car just doesn't want to go anywhere. I'm just trying to narrow it down at the moment but I believe it could be the starter motor, alternator, fuel injectors or me being a douche and not wiring it properly. While popping the dash off I also found numerous electrical oddities such as detached cables. If anybody is knowledgeable or knows of who I should get to have a look it would be really appreciated!
Odd loose cable 1
Odd loose cable 2
