My first VR6
  • #61
    So the rear window when down with a massive CLUNK today, can hear the motor trying to wind it up and down, but it ain't moving
    This would be the regulator yes? Is this the easy fix with the zip tie etc, or much worse?
    96 VW VR6 Golf (Daily driver)
    65 VW Beetle (Under restoration)
    • #62
      Definitely sounds like a regulator. I have fixed one with a cable tie in the past, is hard to explain how though. There is a write about it out there somewhere
      Sent from my HTC Wildfire using Tapatalk
      • #63
        Yeah, have seen the write here also, just wanted to check if that sounded like the standard problem or to try to start sourcing replacement parts...
        • #64
          Fair enough, well yeah, if you can hear that the motor is working the only other thing it can be is the regulator, as its the only thing between the motor and the window. They can break a few different ways so the cable tie fix might not work, it is the most common though.
          • #65
            Well the window is back up again, started to pull everything out, loosened the window clamp and then turned the car on to power the window regulator in the up position and the window went up again, was in a rush, so left it that way
            • #66
              Nothing too much to report, finally fixed my drivers door with a new eccentric kit, hopefully that will be the end of that little hook breaking off the end!!
              Also notice on fleabay, there are replacement window regulators for under $100 each, anyone ever bought one / comments on their quality??
              • #67
                Been a while since I invested any love into my as we have had a love / hate relationship of late, but put some new Brembo rotors and pads on the front today
                • #68
                  Looks the goods.
                  I got a window reg problem to now. A shame since I havent driven the car in 10 months. First time it moves the window went down
                  I saw those eBay regulators, and thinking about getting one. If I do I'll let you know how it is.
                  • #69
                    Ended up fixing my rear window with the forum mod, worked a treat!
                    Was looking at my front window, which is more an intermittent problem, is this also fixed with the same mod?
                    • #70
                      Woo Hoo...new bits!
                      • #71
                        Nice, the expansion tank is something I think every mk3 owner wants!
                        • #72
                          As it snapped off at the bottom hose, was more of a need
                          • #73
                            Classic. How much did it set you back?
                            • #74
                              where from? i'm ordering very soon, was just going to go through GAP?
                              • #75
                                I bought a new one for my vr6 just to freshen things upwhen I had one. cant remember where from but it wasn't very expensive. Would have been from ecs, gap or 1stvwparts
                                Sent from my HTC Wildfire using Tapatalk 2
