Any electrical engineers in the house??
After getting my air con fixed, which as it turns out was a matter of plugging a plug in properly the thermo fans now run @ 100% when the car is on. When you switch off they drop to low speed for a few minutes.
Now I have never noticed the fans on before, so it's likely that the plug that wasn't in right also controls the fan. But then the temps sit dead on 90 so they were probably never needed anyway.
The water temp still seems to get up to 85 - 90 anyway, although I would say it's now slightly lower with the fans on. That and it's damn noisy outside the car and the buzz of the fans can be heard inside too.
Loon has suggested that maybe the temp sensor in the radiator is stuffed and being a cheap enough part it's worth a bash to swap it out for a new one in the hope that solves the problem.
The question is, is the temp reported in the car drawn from this same sensor? That being the case, wouldn't that suggest it is working correctly?
The quick and nasty option is to drop in a toggle switch so I can manually turn the fan off when it's not needed, although the danger being that you then need to be aware when it needs to be on.
Anyone ever have a similar issue to this?
