Mk3 Pollen Filter - Removing leaves from surrounds
when removing the rain tray take your time as the clips can be a real mofo and break... once its off you will be able to remove the leaves by hand or maybe hit it with some compressed air if your lazy.... cabin filter is on the passenger side, maybe just replace it as they are not expensive
Polo GTI
T-Roc R
Tiguan R
Tiguan 162 Allspace Wolfsburg
question .. i get some weird smoke smell through the vents when i take off really fast some times .. and the vents seem to always let air through .. even when the fan is off .. how do i get it fixed ?
VW BORA 2003 V6 4Motion
Volkswagen Golf MK3 1997 CL 1.8L Rammstien + Autobahn + Volkswagen = Leben !
have a look above where the 2 heater hoses are that run into the car, above that there should be a small vacuum line.... check if that is hooked up
Polo GTI
T-Roc R
Tiguan R
It's a problem with probably all Mk3s now - the foam around the blockers when you turn your fan off has come off, letting air into the cabin. If you've ever had foam blown into your face when your fan is on, then you know it's gone.
i thought the foam around the blockers controlled where the air was directed as in towards the face/feet or windscreen ? i have foam flying in for ages and although when i choose for example the windscreen i can feel air coming out the face vents but i can still stop the fresh air from outside coming in when the blower is not on....
Polo GTI
T-Roc R
Tiguan R
Oh yeah ! foam used to blast in my face when i turn the fan on high .. it's not coming out anymore .. Bhahahahahha
