Hey guys,
I noticed some oil on some mounts/cross member which lead me to check the oil level...
I wiped the dip stick clean, put it back in, nothing
did it again, and again, nothing.
How could this be? I haven't noticed any oil leaks on the ground, the car doesn't smoke...
I topped it up, it took around 3.5L to get it back to the normal level on the dip stick...
More examination and I found that it looked like there was some oil seeping around the valve cover gasket (rocker cover gasket).
Car details:
No oil lights flashed
I actually drive the with instrument cluster on the oil temp always (I like to monitor the temp), and oil temp hasn't gone over 102 degrees C lately.
My mechanic usually runs Mobil semi-synthetic (not sure of the specifics), I supplied Shell ultra 5W-40 at the last service.
Could this be the cause?
Not happy!
did it again, and again, nothing. How could this be? I haven't noticed any oil leaks on the ground, the car doesn't smoke...
Car details:
- 1996 Golf Mk3 VR6
- 125 000K's on the clock
- Oil changed every 5000Km's
- Serviced religiously at a VW specialist...
- Last service was around 8000K's ago (I was overseas for a couple of months) but anyway an extra 3000K's shouldn't make a difference...
Not happy!
