Mal's Mk3 Build.
  • #46
    its looking great , any comments on the ride and feel of your superlow ride?
    all i got to say is try to find some cash and time to sort out the dings around your car.
    ~\\VoLkS//~\\MaN//~
    • #47
      Originally posted by schoona View Post
      Will look into it. Best bet? GAP? ECS?
      Needs to come up if I want your euro lip on it too!!!
      If you want a euro lip you better be quick. only a couple left at the current price. Its first in best dressed with those im afraid
      FOLLOW US ON FACEBOOK
      • #48
        http://www.dubaddiction.com.au/index...products_id=61
        Are they from the batch that turned out to not fit so well?
        Originally posted by Ben_GTI
        I like tubgirl more.....but meh each to their own right?
        • #49
          Im order number 339 on september 11, Tim. Whta's this about not fitting so well? Have had a few dramas with the coils already, don't really want to be stuffing around with the lip too. In saying that I was happy buying as you have a good rep and lots of people on here have them.
          Thanks for having those mounts and bearings too. Will look at getting them soon.
          • #50
            Originally posted by GoLfMan View Post
            LOVE IT
            nothing like a VR in the weeds
            Thanks mate
            • #51
              Ride, quite stiff lol. Because I have a few things not quite right I haven't been throwing it around too much at all really. The struts I pulled out would not extend at all so they were well shanked, and because of how close it is to the deck im really conscious of going for a b-road bahnstorm. Point being it's a massive change to what I am used to.
              Once these few issues are sorted (see next post), and it's raised with a good wheel alignment, i'll happily find some twisties and see how it goes. Change in power down, weight transfer, pitching under braking etc etc...
              • #52
                This is how the front struts sit relative to the body. I don't believe this is "quite" right!
                There is a nut below the body, and instead of using the nylock ones, we reused the old ones because we were a little unsure. They sit up by about a nuts length, so if I remove the lower nut, will that get these strut hats hard up against the body?
                LHS:
                RHS:
                • #53
                  ^ same as mine, anyone have any suggestions to what it could be?
                  • #54
                    Those hats that poke up, I just took them off (safe to do so with the car on the deck) and there is a nut underneath. I want these hard up against the body.
                    Can get photos of them if oyu want?
                    • #55
                      mate, they poke up so much because the rubber top mounts are stuffed. you need new ones
                      '98 Mk3 Cabriolet 2.0 8V
                      '99 A4 Quattro 1.8T
                      • #56
                        Exactly.
                        I always change em when installing new suspension.
                        I carry them in stock if you are in need.
                        • #57
                          Thanks Aydan
                          Weird, stuffed ones would lose their integrity, bulge and sag and carry on wouldn't they?
                          Apparently not. Thanks again.
                          Big learning curve, haven't touched this before
                          • #58
                            Originally posted by Golf Loon View Post
                            Exactly.
                            Thanks Matty, how much you looking for? Any different to the mounts (including bearings)in the link Tim posted earlier? I would assume yours are OEM, and his are to OEM specs?
                            • #59
                              We all fixed now.
                              • #60
                                Mine are OEM, including the bearing. His are cheaper, mine need to cost at least $50 each. Either would be better than knackered original ones.
