Just thought that I would share my experience with my ABS issues.
From what I hear (this is a prolific issue with the MK3's).
Owned my Golf for a few months now, purchased it with the ABS light on. Sometimes the handbrake light comes on to.
Troubleshooting, included starting with VAG-COM to see what the problem was. The computer reported rear right sensor.
I did the following:
- Cleaned all the sensors (surprised at how much build up there was)
- Re-seated all the ABS modules and sensor plugs
- Swapped the sensors in the rear
- Ordered a new rear sensor (installed but got the same fault)
After further research, I found out that this is a very common problem with the ATE ABS controller that is bolted to the bottom of the ABS block and Pump.
Firstly, you can removed the ABS controller without removing the brake lines, the pump or making any disconnection to the breaking system. (And the car will drive around without any issues (other than no ABS)
You need a 4mm socked and remove the 4 bolts off the ABS control module.
I did have to bend/ slightly move the brake lines to remove the ATE controller... it just drops straight down. The job took 10min max.
I dropped the controller to http://www.autoelectronics.com.au/ (in Sydney) in the morning - and it was fixed by the afternoon $200 later.
Apparently 99% of all failures in the ATE ABS Controller is dry soldering joints.
Well for me, I could not drive around with lights on the dash, and the ABS system not working, so it was a must !
Hope this helps !
Hope this helps !
 Problems with your ABS?
 I don't think my ABS works. But then again, and thankfully, I haven't come across a situation where I've needed it.
