plugs and leads and notice the difference. if it has been stalling then i would say the coil or do all and not worry about anything it will cost you $500
Hesitation and poor throttle response: VR6
The other mechanic i took my car to last week found the culprit... Timing chain tensioner broke, and skipped a tooth on the front cam causing it to do what it did. Once he opened it up, had about 10-15mm of give on the chain... So a lot of money later and I should be back on the road next week, hopefully with nice compression and 0 hesitation
-Sven
Ha too true, I've officially named the black beast "the money pit" now, I doubt if I'll get much change from 3k (not a nice bill to have straight after xmas), haven't got the final grand total, only cause there was a couple other things that I'm getting fixed up while its in bits. Didn't seem to bend any valves which is a good thing.
Mine rattled for quite a while, but I had one of the tensioners replaced when I had the head gasket go, so that bought me a bit of time. It was a couple months ago, it started to sound really bad. From what I've been told though, its one of those things you want to get sorted before it goes 'ping', as bad, bad things can happen if it does.
My vw had the same symptoms, i checked the leads time and time again thinking they were okay but alas they were arching / shorting on the head. I only noticed this when i had the car in the garage without any lights on.
Car popped and farted just like yours but once it got over 3 - 4000rpm it purred like normal.
ps. Cylinders 2, 4 & 6 are the front cylinders ie. kissing the radiator
Originally posted by william View Postplugs and leads and notice the difference. if it has been stalling then i would say the coil or do all and not worry about anything it will cost you $500. The car is running better atm, but is still missing below 2000. I'm going to order a new adjustable FPR and have that fitted along with some other things when I get the chance...
Originally posted by Golf Houso View PostThis is where I got mine, $250 to your door in 10 days http://cgi.ebay.com/ebaymotors/VW-Co...Q5fAccessories. Did make a big difference initially but then I realised there was more than one misfire going on at any one time. The car is running better atm, but is still missing below 2000. I'm going to order a new adjustable FPR and have that fitted along with some other things when I get the chance...
Originally posted by pisana View PostHave you pulled your plugs and checked them recently? Is there even colouring over all 6 cylinders?80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Well the car is running better, but strangely enough now only begins to develop this problem AFTER 25-30 minutes of continuous driving. If I was to return to the vehicle after say 30-45 minutes it would continue to missfire at low rpm in the same was as described before. I'm going to try to re-set the ECU and see if that makes a difference.
Here is some good reading I have found in regards to a similar problem some 10 odd years ago in a late model VR...
