Just wondering has anyone tried or been successful in finding hubs with the studs on the hub instead of just having the threaded holes there??
Hub Upgrade?
You don't need to change hubs!
You can do a "stud" conversion, and screw in studs to the threaded holes in the hub, and have the studs poking out, and use nuts to lock your wheels on.
For example, check out ecstuning.com, enter your vw>mk3>vr6 details, then go to Suspension, and down the bottom you'll see Wheel Bolts - Stud Conversions - Lug Nuts. You're going to want the stud coversion thingo...
I had that exact same thing done when I had my adapters. Made attaching the wheel easier but that was about it
Mate you are a life saver, I just have to work out what wheel bolts i need now.Originally posted by golf3 View PostYou don't need to change hubs!
Hit the nail on the head there, exact reason why I want to change the wheel nuts overOriginally posted by rayray086 View PostI had that exact same thing done when I had my adapters. Made attaching the wheel easier but that was about it
