g'day -
my first post... & it's bad news...
my mk3 gl has started cutting out intermittently
i searched this - & a couple of overseas fora - & have seen a few threads describing the same symptom, not no definite solution
perhaps someone who has been there could tell me how they fixed it?
here's the scenario:
- once up to temperature (but not overheating) the engine will cut out on overrun
- sharp cutout, like ignition failure
- all other electricals stay on
- engine will fire & run a few minutes later
i had this problem a few months ago; the auto sparky changed coil and crank angle sensor - which appeared to have fixed the problem until about a week ago, when it recurred
i have a wild theory:
- debris in fuel tank
- fast, consistent running sucks it into the fuel pump pick-up, dropping fuel pressure
- ecu has low fuel pressure ignition cut-out (here's where my theory could fall down...)
- once engine stopped, debris falls out of pick-up, allowing engine to run again
does anyone know if this theory stands up?
any ideas at all?
any ideas at all?
