Mk2 VR6 Conversion
  • Mk2 VR6 Conversion
    Hi,
    Can anyone point me in the right direction?
    Is there anyone who does the conversion?
    Thanks,
    Nick
    There's tonnes of information on vortex and European forums. Best to search there.
    I used to own one.
    Used corrado front crossmember to utilze mk3 front mounts. (Can get mk2 to mk3 solid mounts off ebay nowadays.
    If you have a ce2 mk2 the wiring is plug and play except for the tach signal which you will get from the coilpack harness.
    Easiest to swap full front subframe of a mk3 into the mk2. You gain ~2mm extra track, vr6 brakes etc.
