Fuel Injectors
  • Fuel Injectors
    I need info on the fuel injectors for Digifant 1 or 2. Does anyone replace the 2 plastic clips before and after the o ring on the bottom spray jet of the injector ? Are these needed ?
    sigpic MK2 GTI G60
    I guess no one knows about these either ... great forum
    sigpic MK2 GTI G60
      Your questions are too hard!
        I think they are questions where no body cares to care !
        sigpic MK2 GTI G60
          Sorry aussieg60. Dont be hard on us! No, I haven't replaced said parts. Is there a problem with em?
          Tis a good forum...
            I pulled out the injectors from my G60 engine so I can replace the small O rings. There are also 2 plastic like washers before and after the O ring seal that are not listed in ETKA or the injector kit part number 030 198 031 so I'm wondering if they are needed or why did they have them in the first place?
            sigpic MK2 GTI G60
              Can you post a photo?
                photo with the 2 plastic type washers by side of O ring
                sigpic MK2 GTI G60
                  dont have the number, would it be the same as any aussie delivered 8v engine ? Anyone replaced injectors on the 8v digifant ?
                  sigpic MK2 GTI G60
                    I just put the rubber 0-rings on without the plastic on, spray some lubricant on the 0-rings to let them settle in properly.
                    MK4 GTI (KO4, GIAC)
                    VW Kombi Ute 2ltr EFI
                    Audi 90 20V Quattro
                      I haven't replaced the plastic sleeves either
