The saga continues.
I need some advise and knowledge. 1st gear started grinding a couple of days ago.
What happens is: When im shiffting down it will grind basicly. The higher the revs the harder it is to put it in, i dont dare to put it in at any higher than ~3.5k from second. When i try to put it from 3-2.5k in second its realy difficult and grinds in, when its at 2-1.5k in second it will either clunk in realy hard or grind a little then clunk in. It will only go in 'noramly' when its at idel or a tiny bit above.
I say 'normal' because first gear was always a bit tough to shift in to no matter what revs the car was at.
I tryed to align the shifter properly today, i didnt exactly align it perfectly but i did move it a fair bit from where it was, no change to 1st gear grinding.
The gear box is a mk3 box from Matt (Golf Loon). Cant remember how many Ks on it or what box it is exactly.
Another little thing i was wondering is how much 'free-play' is the gear shift suposa have? Mine has some, i wouldnt say its a little play and wouldnt say it way to much play, it a bit in the middle, you can move it about 1-1.5 if not 2cm from side to side without it moving anything in the gear box.
Help needed prity despritly as i dont want to f'up the box. It will mean buying a commodore.
