Hey all. Just wondering if all the power steering parts off a mk3 golf will work with my Mk2 16v, or will I need other gear to get it working. Thanks
Power steering on KR 16v
Sorry I can't give you a definitive answer but I fitted 8v mk2 Gti PS to my KR and that all fitted except I needed to find the right mount to mount the pump. I think mk3 may be a serpentine belt driven pump and therefore a much more complex change. And the reservoir is most likely different shape and location.
mk2 GTi 16v
Corrado G60
the mk 3 reservoir is in a different spot (only by a little bit), but can be mounted if you're a little bit handy . (I have mk 3 PS in my mk 2)
You might be able to use the entire bracket off the mk 3, as well as the alternator (and AC if you have it). But I couldn't give you a definitive answer.
As mentioned mount is differant ,not sure about pumps from experience,have noticed a higher failure rate compared to the mk2 pump,have seen/heard many a noisey one @ fairly low kms,the mk2 pump is a tuff little bugger.
You could make one fit ? have seen it done in reality though.sigpic1987 Golf GLI Wolfsburg Edition,full gti spec 3a Audi 2 litre on dijifant 2
1989 Corrado 1.8 16v KR manual (02a) black 15x7 RH cups
1987 Golf GTI original 3 owner in white.
Audi Quattro,and various Porsches
